How do I make the expression node output show digits of precision?
I am using the expression node to do a simple calculation, x/32-273. It is giving me an integer, example 45 when I want to see one digit of precision, example 45.2. How do I make the expression node output 1 digit of precision? I have been though the help but must be missing it.
(2,772 Views)
The expression node does not determine the number of displayed digits at all. All calculations are made with full precision.
You must ensure two things:
Check the data type. If the wires are blue you are doing integer calculations and decimal digits cannot exit. Inser a "To DBL" before the expression node or change the data type of all input controls and output indicators (Right-click..representation..DBL).
If you are doing floating point calculation (expression node and wires are both orange) and you don't see the decimal digits, right-click on the indicator and select formatting. Choose a format that shows the desired number of decimals.
(2,767 Views)
