You can show all 4 plots in one window or in 4 separate windows. Because one of your data sets reach into the thousands and another of your data sets are very low (less than one), I recommend 4 separate windows. Trying to display all in one window will result in your last two data sets being so close to the bottom that you won't see any resolution. To solve your problem, refer to the attached vi. I have changed your build array into a bundle cluster. I went into the properties page of the waveform chart and selected 4 plots with different colors for each plot. When changing from build array to bundle cluster, you may notice that the chart changes to show 4 windows instead of one. To plot all graphs on one window, right click on chart and select Overlay Plots. To change back to 4 windows, right click and select Stack Plots.
