How do I measure a audio dropout in LabView pro-grammatically with a Agilent DSO6012A?
I have a DOS6012A and I want to measure audio dropouts automatically with Labview.
This is an example of the signal. How can I do this with Labview?
Can you turn the waveform into an array and read the amplitude readings?
And then search the data?
How would that be done?
(2,762 Views)
Do you have the data in Waveform data in LabVIEW yet?
If not, then get the appropriate driver http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=7562 use it to acquire a waveform into LabVIEW and then you can extract the amplitude data and have your way with it.
(2,740 Views)
