How do I open a 7.1VI with a 8.5 labview ?
Some of my Sub vi's are missing when I try to open the file. I was told not all the DAQ drivers are installed. Is there any other way I can try and view the sub VIs ?
(2,681 Views)
There will be no problem, in opening a 7.1 file with LV 8.5
What DAQ ur having? Have u installed all the driver files?
Some of subvi's means how much? what file ur trying to open?
Please give bit more info.
(2,674 Views)
Everything is there except for the 2 sub vi's. Port config and port read.
As for the DAQ and driver files, I'm not too sure. My boss sends someone else to do the installation part. And I need to open the file so that I can test it with the hardware. (The project is about sensors)
(2,666 Views)
There is this pop-up that says its looking for zadvd.llb.
(2,664 Views)
Check post no. 3 here
(2,652 Views)
