How do I place text vertically in a string indicator? See description below (code attached).
This is what I'm getting when I'm running the code:
This below is what I would like to get instead.
How to achieve this?
Message 1 of 12
(2,110 Views)
Accepted by GRCK5000
Just simply add an EOL constant to it.
https://tmesystems.net/
Message 2 of 12
(2,104 Views)
Great! Thank you, ZYOng!
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Acts 20: 35 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Message 3 of 12
(2,094 Views)
I'm working on an XControl that's a string indicator with changeable vertical orientation.  I'll post it when it's ready.
Message 4 of 12
(2,007 Views)
Hi GRCK,
so you want to interleave the chars in your string with the same number of LF chars?
Try this:
The main part is the Interleave1DArray function, the stuff around that is just to create the strings you want…
Message 5 of 12
(2,003 Views)
Thank you GerdW! This is awesome! It's always a good thing to learn different ways of doing thing.
Message 6 of 12
(1,981 Views)
Depending on what you're doing, you might want to throw in a "Trim Whitespace.vi" at the end. Both solutions so far have an extra newline after the last character.
Message 7 of 12
(1,975 Views)
Or just put a Decrement function after the String Length.
Message 8 of 12
(1,965 Views)
Hi Paul,
@paul_a_cardinale wrote:Or just put a Decrement function after the String Length.
Interleave1DArray might give "unexpected" results for input arrays of different length…
(Btw. my snippet only works with plain ASCII. Handling Unicode strings the same way might also introduce "unexpected" results…)
Message 9 of 12
(1,948 Views)
@GerdW wrote:
Hi Paul,
You're right; it won't work correctly (because the input arrays are truncated to the length of the shortest one.
Message 10 of 12
(1,927 Views)
