How do I programmatically change the display format radix of a numeric array?
(4,461 Views)
Basically, create a reference to an element in your array. Pipe that reference into a property node and select the "Display Format -> Format" property. See the attached VI for an example.
(4,447 Views)
Whoops... and make sure you select the "Show Radix" option, which I did not do. 🙂
Here is a better example:
(4,444 Views)
Thanks.  I was looking in the wrong place for the Display Format method.
(4,422 Views)
Glad to help!
(4,417 Views)
