How do I programmatically change the plot legend names on my xy graph?
I have a need to change the names/labels on my XY Graph's Legend at run time.  This is because plot 0 is not always the same set of data.  I have searched high and low for a couple days now to no avail.  The closest thing I've seen is overlaying a string over the plot legend, but I would prefer to do change the property of this box.  Any help would be appreciated.
Message 1 of 18
(27,348 Views)
Hi Superlux,
try this:
Greets, David
Message Edited by daveTW on 06-13-2007 05:56 PM
Greets, Dave
Message 2 of 18
(27,341 Views)
  1. Right click on the Graph >> Create Property Node >> Active Plot
  2. Right-click on the lower part of the property node >> Add Element (you can also resize the property node by pulling its lower border down)
  3. Click on the lower property >> Plot >> Plot name
  4. Right-click on the upper part of the property node >> Change All To Write
  5. Wire the number of the plot to ActPlot and the name to Plot.Name
Message 3 of 18
(27,340 Views)
One time in picture and one time in text... daveTW sent his answer while I was typing mine !
Message Edité par JB le 06-13-2007 06:05 PM
Message 4 of 18
(27,336 Views)
Once again the forums are to the rescue!
Patrick Allen: FunctionalityUnlimited.ca
Message 5 of 18
(27,324 Views)
So it looks like we have a virtual tie.
So now for the tie-breaking question (are you ready?)
When using a waveform datatype with charts and graphs, what property should you check if the previous suggestion does not work?
Ben
Message 6 of 18
(27,311 Views)
Hello Ben,
with waveforms this also works for me fine. So where is the pitfall? (if always all works fine, one don't really gets experience)
greets, Dave
P.S. @ J.B. I used the Code Capture Tool from the Starware Thread, this made me so fast. If I could do, I would give it five stars each time I use it.
Btw. would it be possible to programmatically give ratings with LV? Here it should be used. Thanks again to tst & the others Smiley Very Happy
Message Edited by daveTW on 06-14-2007 09:13 AM
Greets, Dave
Message 7 of 18
(27,295 Views)
Ah but if your waveform had attributes...
then the "ignore attributes" option would prevent the graph/chart from using the names included as one of the WF's attributes.
I believe if you use DAQmx channels, these come automatically.
Ben
PS Yes you can give stars with LV.
Message Edited by Ben on 06-14-2007 06:06 AM
Message 8 of 18
(27,281 Views)
I have been using a very nice tool called HyperSnap for years. But most of the times - at least if I don't know anything about the LV level of the author of the question - I prefer to describe the exact procedure to follow.
Message 9 of 18
(27,271 Views)
you guys are awesome!
thanks for bringng this up.
Message 10 of 18
(26,756 Views)
