How do I programmatically change the plot legend names on my xy graph?
PAY ATTENTION!!
The properties of Settings are NO PARALLEL! They are sequencial!
They will be executed in seqeunce.
I attach 2 examples:
  • The first is KO -> You we'll experience an error!
  • The second OK -> No Error
In my opinion this is a bug.
For now this is the correct solution.
Ciao!
Carmine
Message 11 of 18
(2,795 Views)
Hello Carmine.
This is not a bug. This is expected behavior. The help for property node clearly states: 'The node executes from top to bottom.'
How would you handle something like the attached picture in parallel?
UliB
Message 12 of 18
(2,772 Views)
Thank you for your answer! Smiley Happy
Your example is so clear, in no way it can bring us to a not wished situation.
For example in my real time application I need to customize the name of graph-lines.
In this case (please see my examples) you can have e total wrong name configuration.
From a function that i call, the expected behaviour is that it wait for all input and set it all together with priority for "ActPlot" number.
If you have a complex software this behaviour can conduct you to lose so many times.
Thank you for your attention!
Carmine
Message 13 of 18
(2,763 Views)
What about multiple graph lines... Plot 1, Plot 2, Plot 3.... is it really just the first name element? or can I get to the other plot name labels too?
Message 14 of 18
(2,286 Views)
You're replying into a 2 year old thread and your questions aren't clear as to what message you are referring to.
What specifically do you mean by "first name element"?
If you are having an issue with your VI, it would be best if you create a new message thread and include your VI along with an explanation as to where you are having problems.
Message 15 of 18
(2,282 Views)
I figured it out.  ActPlot was the key.
Message 16 of 18
(2,268 Views)
I had a question typed here but then realized I was being dumb. I resolved it but couldn't delete my comment.
Message 17 of 18
(615 Views)
My plot labels are read from a text file during initialization and put in a string array.
Then I do this:
It's a "strict" property node because it's in a sub-vi and a uses a reference
=== Engineer Ambiguously ===
Message 18 of 18
(604 Views)
