How do I programmatically deploy a VI to a target?
The document had an error in it.  It was taken off the web to be edited.  If you are trying to programmatically FTP a file over to a Real-Time target check out this KnowledgeBase. You use the FTP Put File.vi to do this.
Jon S.
LabVIEW NXG Product Owner
Message 11 of 12
(770 Views)
I forgot to link the KB I mentioned.  Here are two KB's that will demonstrate how to FTP a VI to an RT target and then run it using VI Server.
Jon S.
Message 12 of 12
(746 Views)
