How do I properly build a dll in cygwin (gcc) that can be loaded through Labview 5
I am a newbie to building dlls as well as to cygwin. I realize that this is more a cygwin/gcc dll build question, but I have built a dll (using cygwin) that can only be accessed by running an executable through cygwin. When I try accessing a function in the dll through labview, I keep getting a "function not found" error, even though the parameters etc are correctly passed.
If anyone has built a dll through cygwin (and has had success using it through Labview), I would appreciate directions on how to do so properly.
Thank you in advance.
(4,595 Views)
Yes, this is a cygwin support question, so I won't be able to help you much from the LabVIEW side. Just make sure you follow the instructions in Using External Code in LabVIEW manual on gcc compiler.
Building and Using DLLs
Zvezdana S.
(4,595 Views)
