Markus,
Do you have NI-VISA and NI-488.2 installed on your computer? Also, go into Add/Remove Programs -> NI Software. Do you see the Instrument I/O Assistant listed there? Maybe you can try performing a repair?
If you are using a Mac, the Instrument I/O Assistant is not available to use. It is only for Windows.
Good luck!
