Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How do I pull binary data apart?
labvnewbie
Member
07-26-2002
02:51 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I have two waveforms encoded in a 16-bit binary format. I can read the data in fine, but I can't quite split it into two waveforms one on each graph. Instead, I have both waveforms showing up on the same graph. Any suggestions?
0
Kudos
Message
1
of 2
(2,868 Views)
Reply
Re: How do I pull binary data apart?
Ben
Knight of NI
07-28-2002
08:32 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
If you had posted an example I am sure we would be able to help. Lacking such I will guess.
Try running your data into a Index array node. Wire an "0" into the collumn index. This should give you the first channels data.
Do the same using an index of "1" to get the second collumns data.
If this guess is bad, please post eaxample.
Ben
Retired Senior Automation Systems Architect with
Data Science Automation
LabVIEW Champion
Knight of NI
and
Prepper
LinkedIn Profile
YouTube Channel
0
Kudos
Message
2
of 2
(2,868 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
