How do I read data from memory on the host PC that is being written by another program
Hello everyone,
This is my first post.
I am very new to LabView and I have only just completed Core 1 and Core 2 with no prior LabView experience.
I have a SilconSoftware frame grabber with an FPGA board on it to capture and pre-process images from a CamerLink sensor. The FPGA has been programmed to output a 64 bit image using DMA to the host PC, and I know the address of the Image. The image consists of two pixels, I would like to read the pixels in LabView so I can decode the information.
How can I do this?
Thank you _KAL
(3,211 Views)
Accepted by _KAL
I am not familiar with this particular hardware, but the easiest way is if the camera is compatible with IMAQ. Alternatively, does the vendor provide a DLL for accessing images?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,202 Views)
Okay, so I wasnt very clear.
The 64bit image out (1 pixel by 2 pixels) has data encoded into the pixel value, it is not an image I want to view.
Eg
The first pixel of the (1 pixel by 2 pixels) image contains a 64 bit number: 3411507556003349746.
If you convert the number on the 0 - 15 bit of this number to binary and then to decimal it will output a number that is a coordinate in x on the image captured by the Camer Link camera.
If you convert the number on the 15 - 31 bit of this number to binary and then to decimal it will output another number that is a coordinate in x on the image captured by the Camer Link camera.
If you convert the number on the 31 - 47 bit of this number to binary and then to decimal it will output a number that is a coordinate in y on the image captured by the Camer Link camera.
If you convert the number on the 47 - 63 bit of this number to binary and then to decimal it will output a number that is another coordinate in y on the image captured by the Camer Link camera.
Appologies if this isnt very clear? So I can get access to the memory loaction of this 1 pixel by 2 pixel data, can I access it in LabView knowing the memory address?
(3,192 Views)
