How do I read input data on a TDS 210 using Labview 5.1
I am trying to read the data from the TDS 210 scope and see the data
on the screen. How do I do this?
(2,777 Views)
Hello, I have the same model of that scope here at the lab.There can
be two ways you can do this one is using the Wavestar software from
Tek and yes, using LabVIEW. Common to this is the use of a Serial
Interface (or GPIB if you wish) that has to be purchased separately
from Tektronics, also a null modem and serial cable (DB9) with your
version you have to code it using VXI drivers or low level serial VI
component library. Read exactly the string command formatting of your
Tek manual and send them thru your PC or notebook serial port.
(2,777 Views)
