How do I reinstall NISVL library
I am getting somer errors that tells me I need to update the help links in files that exsist within the NISVL library.
I need to update the vi.lib\addons\NISVL library. Can someone tell me how can I do this?
I have the original disks but cannot find NISVL.
Thank you,
Dominic Lacatena
(3,116 Views)
The National Instruments Sound and Vibration Library (NISVL) is an add on toolkit that is purchased separately.  I assume that you have it.  If you do, I am not sure what you mean by updating the help links.  Have you moved the VIs from one version of LabVIEW to another and not moved the help files?
What have you changed to make you start getting this message?
Bob Young
(3,114 Views)
I reinstalled the Sound and Vibration toolkit and was able to fix the problem.
It seems that labview likes to change the VIs that contain incompatible block objects based on the version of labview that you are running.
I chose to save all the files which in turn corrupted the links to the help files.
Problem is fixed.
Thank you,
Dominic Lacatena
(3,106 Views)
