How do I restore default font sizes for all screens?
I am unable to read the complete 'find examples' menu because the font sizes are incorrect. How can I go back to the default font size from when I originally installed labview?
Rob Steele
(4,081 Views)
i beleve that you need to re-install labview
(4,066 Views)
Errr... before taking this somewhat drastic step let's try to see what's going on first..Smiley Happy
First off, which version of LabVIEW are you running, and on what platform?
Second, not sure what you mean when you say "
unable to read the complete 'find examples' menu" - which menu are you talking about? In LabVIEW or in the Example Finder? 'Cause there's no menu in the Example Finder in 7.1
Third, you can manually edit the labview.ini file and the .ini file for the Example Finder to delete entries related to fonts that may have been accidentally placed in there. The labview.ini file is in the directory where the LabVIEW application is. The ini file for the Example Finder (at least in Windows) is in the National Instruments\Shared\Example Finder\1.0\BIN directory, and is called "NIExampleFinder.ini". The keys you're looking for are "appFont", "dialogFont", "FPFont", "systemFont". If you see these keys, just delete them.
(4,053 Views)
If you are running windows, also check the display properties.
Make sure the font size is set to "Normal" and not e.g. "large font" ("Control panel..display..appearance" OR "...settings..advanced..")
DIsplay fonts can also change if you change the "Theme".
(4,049 Views)
After getting things approved I can now put a picture of my problem on a website. The url for the image is http://automation.jpl.nasa.gov/steele/labviewScreenShot.jpg
the account name is labview and the password is labview
I'm using labview 8.0 and running on a Windows XP Pro Machine.
Rob
(4,030 Views)
I can reproduce this by setting the Windows display to "extra large font".
Right-click on your windows desktop background and select properties. Go to the "appeareance" tab and check the font size. It should be set to normal.
(4,024 Views)
The last suggestion solved my problems. Thanks, Rob
(4,005 Views)
