How do I retrieve a hWnd required to draw an image created by an ActiveX object on a windows 7 64-bit system?
I'm calling to the NaturalPoint Optitrack SDK using activex controls and am trying to pull tracking data from a trackIR 5.  I have connected to the camera and wanted to start by just viewing a captured frame.  The Optitrack COM provides a function to draw the frame, but needs a hWnd handle for a window to draw to.  I tried to call FindWindow from the user32.dll, but only found FindWindowA, FindWindowExA, FindWindowW, and FindWindowExW.  I'm using Labview 8.6 (32-bit) on a Windows 7 64 bit system (trying to figure out how access the universities liscense manger to install LV2010 64 bit).  Thanks
Jarad
(2,738 Views)
The other functions are variants, depending on how you're dealing with strings:
FindWindowW : Unicode names
FindWindowA: ANSI names
FindWindowEx: Searches child windows for the window that has the specified name. You can provide a parent window handle as a starting point. The "A" and "W" follow the same Unicode/ANSI names as FindWindow.
You'd want to use FindWindowA or FindWindowExA since LabVIEW doesn't support Unicode.
(2,724 Views)
