write a string by (visa write) per character
I want to know how to write a string using "visa write" character by character and read later with a "visa read"
I tried with a for loop, delay, and the object "spreadsheet string to array" and I failed to do so, I think I did not clearly specify its inputs (format string and string spreadsheet )
Please give me an example or clarify me how to do it.
Thank you in advance
(3,593 Views)
Try the example here.
(3,574 Views)
Your "Spreadsheet String To Array" functions needs a correct format string.
Try  %s
Omar
(3,568 Views)
The usual and easy way to use Visa write is to write a full string at once, and not character by character. Remember to open and close the visa port before trying to send and recieve anything.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,548 Views)
