How do I save the current VI front panel to a video file?
I know how to screenshot the front panel to a image file, but is it possible to save the front panel of my VI to a video file? If so, how do I do it?
Thanks.
More info (if needed):
I am reading in .csv data which has time vs. five independent variables. I am writing a VI that will take that data, use it to display on the front panel, and then save that video in "real time" i.e. I would use the time data to delay the actual time interval in the front panel update loop. Is this even possible in LabVIEW?
(2,860 Views)
Accepted by topic author Imozeb
If you have the vision toolkit, you can take a look at this example.  The only difference would be instead of calling the user32.dll to "print screen" you would just use the FP.Get Image function
(2,841 Views)
Cool! It works.
Thanks!
(2,798 Views)
