How do I set my 6534 board to read in at port B, line 2?
Hi All,
After many trials, I still could not
get my 6534 board to read in data
at port B, line 2, or any other port or line.
I thought I pick port 1 and line b'10, or port
1 line 2, but I still cannot do this.
Could you guys help me out?
I am using the Buffered Pattern Input.vi.
I just couldn't understand how to use
the port list control.
Thank you in advance.
(2,922 Views)
Have you ran board diagnostics in MAX to verify hardware is OK?
(2,913 Views)
Yes, I have ran MAX and the board is there.
I've talked to the tech help today and
he said for this board, I can only read or
write the whole port at a time, not a single
line. Not for "Buffered Input" anyway.
Thank you for your help.
Do you have any suggestion?
(2,909 Views)
Hello Van626,
Check the manual below for control lines connections and configurations. It is important to know which protocol you will be using to communicate with your external device. i.e. Handshaking, pattern I/O...
Chapters 2 and 3 will give you a lot of information on how to configure your board.
http://www.ni.com/pdf/manuals/371464d.pdf
(2,899 Views)
The manual is located at http://www.ni.com/pdf/manuals/371464d.pdf . Not attached to the post....
(2,897 Views)
