How do I specify the file extensions when opening a file in Labview?
When opening a file, the file open dialogue box appears with a drop down box called 'Files of type *.*
I want to only display files of type IPC, and I will create all my files to have this extension.
I have been using this technique in VB for some time, but I cannot find a method of doing this in Labview so far, can anyone help?
(3,994 Views)
If you have a path control, you can right click it, select Browse Options and change the pattern. This is also available in the file dialog VI. You can also set this by using a property node.
___________________
Try to take over the world!
(3,990 Views)
Use the function "File Dialog" and wire your type to "pattern label".
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,990 Views)
Thanks it does help, it solves it.
(3,981 Views)
