How do I start Labview exe with front panel minimized?
Is there a method in the Labview 7.1.1 environment to allow me to start an exe with its front panel minimized. I currently minimize the front panel when it first starts, but you see the FP pop up and display, then it disappears.
Any help appreciated,
Howard Spec
(6,298 Views)
From the top level vi bring up VI Properties.  You should be able to set category Window Run-Time Position to Minimized.
(6,294 Views)
t think runtime position is avaliable in labview 7.1.1 but you can use openFP method with the state set to minimize.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(6,284 Views)
Hi
You reach this function with a property node too.
Create Property node -> Select class: VI -> Properties/Front Panel Window/State.
regards
Mitulatbati
(6,084 Views)
Thanks Mitulatbati, I am currently using this method, but it does not solve the problem of the front panel briefly appearing before it is minimized. I have not been able to find a way to prevent this.
Howard
(6,060 Views)
Hi Howard,
I use this method as well, but not I call this property node not directly in the VI, which I want to open hidden. If you first open the reference of your VI, and then call this property node, it works. As the called VI opens, it does´n appear, not even for a short time.
I use LabVIEW 7.1.1
(6,032 Views)
...sorry for the mistyping. I don´t call property node in the example, but an "Open FP" method via invoke node. By the way, the same should happen, if you use the "VI -> Front Panel Window -> State" Property.
(6,029 Views)
