comment utilise on un clusters?
comment utiliser un cluster pour avoir plusieur presentation (panel:bp...) de sorte de n'avoir un seul programme.
Je voudrait pouvoir utiliser 5 calculatrice differentes( presentations differente :pas les memes boutons) en un seul programme via un menu deroulant.
(2,510 Views)
Hi.
To get an answer on this part of forum you should post in English.
The french forum is here.
LABVIEW has some examples with clusters I think, have you already seen them? They shoud be helpful.
Could you attach some screenshots to explain what you want to do, or attach your code too.
Thanks.
Best Regards.
Romain D.
National Instruments France
(2,484 Views)
