opc client not updating
Hi
I have created two OPC client that are reading on the same OPC server (UniNETOPC), but the fist application is updating correctly, the second is very slow, Why?
(3,622 Views)
Hi
after many test, I have noticed the real problem:
My project contains an OPC client, 4 main shared variable library, each of them is made by 20  shared variable at least, and finally 4 VI.
Each VI is very simple program, it contains a while loop, with the 20 shared variables inside and the outputs of this variables for the frot pannel.
The updating of the shared variable depends strongly from the number of the shared variable in my OPC client. In fact if I unbind all the shared variable except for just one,
the update of this variable is very fast, otherwise if I bind oll the shared variable, the updating  is very slow, quite 5 min. Please, help me
Vincenzo
(3,604 Views)
Hello Enzo,
Did you try reducing your shared variable number? Did you observe any performance changes? What about the type of your variable you are using? You can try to put these variables into an array and let the application improve its speed access. You also can modify the OPC update time and let the delay changes according to your need.
Finally could you evaluate to adopt DataSocket instead of shared variables? DataSocket connections work quite a bit faster than shared variables, even with read and write on the same machine, and they just seem to be more generally reliable on a congested network.
Let me know about your application
Regards
Matteo
(3,584 Views)
Hi Matteo
I have reduced the number of my shared variable and it works correctly. My shared variable are int16,
how can I put this variable into an array?
Moreover I use an OPC update of 0ms (the fastest possible).
If I use the DataSocket, can I show simultaneously more than one shared variable?
thank
Vincenzo
(3,581 Views)
Hello Enzo,
I noticed that you posted few days ago a similar question on the forum, which received several replies. There's something diffent between the two projects? Anyway i suggest you not to duplicate posts that concerns the same argument and continue on the first one.
Regard using Shared Variable with DataSocket, please refer to this document.
Matteo
(3,567 Views)
Hi Matteo
I learn how read a shared variable with DataSocket, but If I want to open more variable simultaneously, I have just repeat many While loop, or there is a manner to use only one while loop?
(3,565 Views)
