How do I sum similar elements in one column and then correlate it to a 2nd column of data
This may be a very beginner type question but I would like to be able to add the similar elements in column A and get a sum total.  I would like to get a total of the different elements in B (sum of c's and d's).
Then I would like to then correlate elements in B with the elements in A that are of the same number.  The B column needs only to give one data either  c, d or (hybrid c & d)  So for data set 1 the output would be c, data set 2 the output d, data set 3 output d, data set 4 the output would be hybrid (c&d) and data set 5 output c.
Then I would like to sum the outputs above.  The total would be 2 c's 2d's and 1 hybrid.
A       B
1        c
1        c
2        d
2        d
3        d
4         c
4         d
5         c
I hope I explained my question clearly and I thank you for your time.
(3,383 Views)
Hi gweee,
I think this could be handled very easy using the array-functions (Functions Palette>Array) in LabVIEW. What functions you would need to use, just find out with the Context Help!
Regards, Christian
P.s.: "Learning by doing" Smiley Wink
(3,365 Views)
Thanks for the reply....nothing is simple for me at this point.  I would grealy appreciate your thoughts on my VI.  This completes the first part of my question. (I am sure that there is a better way).  I don't think I could solve this or the second part via the show help function. Once again thanks for your help.
Derek
(3,353 Views)
Christian,
I accidently gave you 1 star. I have tried to make up for it in other random threads
Sorry about that.
David
(3,327 Views)
Here it seems you just want to count, sorting is not really needed. 🙂
One simple solution would be the attached VI.
(3,299 Views)
Hi!
@David    no problem!
@G-test   Does it work now with altenbachs suggestion?
Chrisitan
(3,265 Views)
