random number generation with LabVIEW FPGA
I would like to implement some random number generation in LabVIEW FPGA. In fact, I need to generate a PWM signal with a fixed duty-cycle but with a frequency randomly varying for each period of my signal between 18kHz and 22kHz.
That's why I would like to generate a random number on the FPGA, and use it to calculate my random frequency.
Did someone already do something like that ? Is some algorithm (like the Random Number function for LabVIEW Windows) already exísting ?
Thanks in advance for the help,
Laurent
(4,996 Views)
Hi Laurent,
Check out this DevZone article:
http://zone.ni.com/devzone/cda/epd/p/id/1740
You should be able to extract the Uniform generator out of there pretty easily.
-Jim
(4,978 Views)
Thank you Jim, this what I was looking for !
Laurent
(4,936 Views)
