How do I take a derivative of discrete indexer data in a simulation loop?
We have a counter value coming in from a DAQ assistant measuring revolutions of a flywheel with 23 indexing slots.  We attempted to use the derivitave x(t) vi in a simulation loop to provide a fourth-order central difference derivative of the counter values with respect to time, but this has not worked in any configurations we've tried so far.  Does anyone have any ideas on taking the derivative of discrete data?
(3,247 Views)
Attached is a Vi of the method we are trying to use.
(3,239 Views)
Since you are using SIM loop, why dont you try using Derivative in CD&Sim?
Andy Chang
(3,227 Views)
Well, we used the "s" derivative in CD&Sim, but with discrete values, the derivative vi returned large spikes in the derivative value.  We are trying to obtain smoother data with the derivative x(t) vi.
(3,224 Views)
I see. To implement discrete derivative, you can do the following
The simplest way is to drop down a Derivative x(t) PtByPt.vi into the Simulation Loop. After inserting the Derivative x(t) PtByPt.vi, right-click on this VI, select SubVI Node Setup..., and choose Discrete under Simulation subVI execution type.  Choose a fixed-step ODE Solver, such as Runge-Kutta 1 (Euler), in the Simulation Parameters tab of the Configure Simulation Parameters dialog box
Andy Chang
(3,196 Views)
