Application Error on loading DLL ( NI-Daq LIC)
Hi all,
   I have an application developed using port read,Write & config from zadvd.lib ( lvdaq.dll) which is working fine in my XPmachine. In new machine i have installed labview 7.1 and copied the application and while loading the application it shows an error:
     Error Loading C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\Daq\lvdaq.dll . Application has failed to start because application  configuration is incorrect. Reinstalling the application may fix this problem.
  I have referred the NI forum solutions which tells to install .Net Framework 3.5 or copy dll to the folder where application is. Bit confusing . Somebody can help me to solve this problem.
(2,750 Views)
Accepted by topic author Augus
(2,736 Views)
