How do I take a screenshot of my entire block diagram?
I need to take a screen shot of my entire block diagram, but it is way too big to fit onto my screen as is.  Is there a way to somehow shrink it down so that I can take a screen shot and put it in my report?
Thanks in advance!
Message 1 of 8
(13,453 Views)
Accepted by MattSin
try this.
Or you would simply "select all" and "edit...create snippet from selection" (not sure iit is available in 9.0).
Or try the code capture tool
Message 2 of 8
(13,448 Views)
Sorry, I don't have DAQ, so many subVIs are blank, but here's how the snippet would look like.
Message 3 of 8
(13,444 Views)
Thanks!! I used the snippet trick! Appreciate it!
Message 4 of 8
(13,436 Views)
just press "ctrl+P"
Message 5 of 8
(11,275 Views)
Another way to do it, as indicated by wasgij is to print the document.  In this case Print to HTML, include the block diagram and then grab the image from the images folder created.  (This is kludgy, I know, but it is a method.)
Jon D
Certified LabVIEW Developer.
Message 6 of 8
(11,257 Views)
Or you could try using a proper program architecture to begin with instead of a flat sequence and linear programing...
In the vast majority of cases programming LabVIEW, if your code is too big for your screen, you are doing it wrong!
=== Engineer Ambiguously ===
Message 7 of 8
(11,235 Views)
VI Snippet tool is the best one to use. Thank you.
Message 8 of 8
(10,169 Views)
