How do I take multiple consecutive measurements from a frequency counter and keep the previous measurement?
I'm sorry I am very new to lab view and I am trying to take multiple consecutive measurements from a frequency counter. I place both the measurement sub VI and the indicator with in a for loop and then set N to the desired number of iterations. The problem is I only get one box in my display panel when I need all of the previous measurements taken for that iteration. Thanks for your time.
(2,428 Views)
Accepted by JosephClark
Wire your data from inside the loop to an object outside the loop. Right-click on the tunnel and enable Indexing. You will have a 2D array (if your data was in 1D) where each line (either row or column, you'll have to figure out) is the result of a different iteration.
You can separate the 2D array using the Index Array vi.
(2,420 Views)
