How do I the range of a 2nd y axis?
I have created an xy graph with two y-axes and have associated plots 0-5 with y scale index 0 (Plot.YScaleIdx) and plots 5-11 with y scale index 1. I would like to change the minimum and maximum of each of the y ranges programmatically. I've tried making different plots (associated with different axes) the default and changing the YScale.Range.Minimum or the YScale.Range.Maximum property. But this always affects the same scale no matter which plot is the default. Can anyone tell me how to select the y-scale that these properties affect?
Using LabVIEW 2012 32-bit on Windows7.
Tom
All statements are my opinion and worth every cent you paid for them.
Tom Whitaker, CLD
"Give every man thy ear but few thy voice."
Polonius in Hamlet.
(3,011 Views)
Somehow the word "change" was dropped out of the subject - sorry.
Tom
Tom Whitaker, CLD
Polonius in Hamlet.
(3,010 Views)
Accepted by topic author TJWhit
If I understand right, you need to set the Active Y Scale property before changing parameters for that scale.
Tim Elsey
Certified LabVIEW Architect
(3,005 Views)
Thanks Tim. I must have looked at the properties five times for exactly that. Ah well, I'll look harder next time before posting.
Tom
Tom Whitaker, CLD
Polonius in Hamlet.
(2,999 Views)
