How do I trigger a digital output using calendar
how do I trigger an digital output on/off at a certain time and a certain date using MS activeX or a similar calendar?
(3,305 Views)
This should be a simple task by just reading the present time and date continuisely from the LV get date and time and compare it with the set{time and day when the DIO has to be on/off } and use it in a case structure for triggering. For setting the Alarm date and time you can use the Active X calender or LV7.1 Calender function.
vicky
(3,305 Views)
Hi Vichy
Thank you for your answer, but do you have or know where I can find an example VI for this problem?
Regards
Sjur
(3,305 Views)
Plz See this example ,it should help you.
(3,305 Views)
Tankx lot, that did the trick
Regards Sjur
(3,305 Views)
