How do I use Route Signal with a 671x device?
I would like to use the Route Signal VI with my 6713 analog output device to route the AO Start Triger to the RTSI bus. I have re-written the AO Waveform Generate VI to include Route Signal after AO Config and before AO Write. It seems to work okay if I set Generation Count to 1, however, if I set it to anything greater than 1 the VI hangs, usually at AO Wait. This often reqires Ctrl-Alt-Del to close LabVIEW. Once I get LabVIEW back up the card is somehow busy and the VI crashes at AO Config. The only way I get can my system back is to reboot the entire computer. What am I doing wrong with Route Signal (AO Waveform Generate works fine normally)?
Message 1 of 1
(2,363 Views)
