How do I vary the voltage of a DC power source in a sine pattern around a certain voltage?
If you right click on the 15 constant, select Representation then change to DBL. I get the same error message, and I don't have a com port configured on my PC, check what you have in your GWinstek channel. You should also put a VISA close after your VISA read.
Message 21 of 21
(363 Views)
