How do find the DAQ Assistant in LabVIEW 2009 Student Edition
I took the Core 1 and Core 2 courses in LabVIEW 2009 this past June. When I went to use the Student edition I have of LabVIEW 2009, I could not locate the DAQ Assistant. This is going to present quite a problem when I come to use it in class this fall. It works fine on my 8.5 version.
(3,654 Views)
Accepted by topic author cybergod
You have to install DAQmx, just like you had to do with 8.5.
(3,651 Views)
Have you installed the device drivers?  They are on a separate CD/DVD.  I don't know how the student edition is distributed.  The DAQ assistant will show up once DAQmx is installed.  It is available for download from http://joule.ni.com/nidu/cds/view/p/id/2113/lang/en
(3,649 Views)
Thanks. That was the next thing I was going to try. I assumed I wouldn't have to reinstall the drivers.
(3,626 Views)
