‎08-24-2010 02:48 PM
I took the Core 1 and Core 2 courses in LabVIEW 2009 this past June. When I went to use the Student edition I have of LabVIEW 2009, I could not locate the DAQ Assistant. This is going to present quite a problem when I come to use it in class this fall. It works fine on my 8.5 version.
Solved! Go to Solution.
‎08-24-2010 02:54 PM
You have to install DAQmx, just like you had to do with 8.5.
‎08-24-2010 02:55 PM - edited ‎08-24-2010 02:55 PM
Have you installed the device drivers? They are on a separate CD/DVD. I don't know how the student edition is distributed. The DAQ assistant will show up once DAQmx is installed. It is available for download from http://joule.ni.com/nidu/cds/view/p/id/2113/lang/en
‎08-25-2010 01:12 PM
Thanks. That was the next thing I was going to try. I assumed I wouldn't have to reinstall the drivers.
