How do graph output from a serial port when I don't know exactly what signal its sending?
Hello all,
I recently started learning LabVIEW for work and I'm really liking it so far. I am looking for a function that can take a given COM port and tell me what is coming out of it (so that I can add other functions to it and make a graph). I found DAQ assistant under express->input->DAQ Assistant. Unfortunately you need to tell it exactly what it is looking at for it to work (voltage, thermocouple, velocity, ect).
if you want some context, I am trying to automate a power supply, and the manuals that come with it are not at all detailed so I cant tell what exactly is coming out of the RS-232 port, other that 'Transmitting signal, receiving signal, COM signal'. I would love to have a temperature reading from the RS232 but it doesnt look like it will be that easy.
Any thoughts?
(1,348 Views)
Most programmable instruments have a programmer's guide.  What's the make and model?
Bill
CLD
(Mid-Level minion.)
(1,342 Views)
Accepted by topic author Josh_Music
Without the according Programmer Reference Manual it is at best cumbersome, at worst impossible to do what you want to do.
RS-232 is simply a byte stream, usually in ASCII but not necessarily so. If it is ASCII you can simply look at the text stream in a terminal and try to deduce the format, but that is still cumbersome. If it is binary, chances are minimal to retrieve meaningful data in a consistent manner without a full documentation of the protocol.
Rolf Kalbermatter  My Blog
(1,308 Views)
We are using a createc power supply 3504 1 serial 598. Full name is (CU-3504-S1-DC-120V CU-598). It contains a Eurotherm controller with a very detailed  guide, but even after asking the producer for a detailed manual, all that they could supply was how to use the machine.
(1,297 Views)
So did you solve the issue?
Bill
CLD
(Mid-Level minion.)
(1,285 Views)
