How do i add custom task-oriented browse paths to the example finder?
Is this possible, or are the browse paths limited for better integration with the on-line community?
-Matt
Message 1 of 8
(3,711 Views)
Let me make sure I understand your question correctly, because I may have to do some research in order to answer it.  Are you asking whether or not you can add a folder of custom examples to the example finder when you browse according to task?  The idea being that you would like to create some examples and make those available in your example finder.
I have attached a screeshot/mockup of what I described above (as an attempt to understand the question) - I did not actually add a folder named My Custom VIs, I simply doctored the screenshot in paint.
I look forward to your repost, and please also note that I may not be able to disclose such information even if it turns out to be possible.
Best Regards,
JLS
Best,
JLS
Sixclear
Message 2 of 8
(3,695 Views)
Thanks for responding.  Yes, that's exactly what I would like to do: create custom paths for examples that may not fit in very well with the default tasks.  I know how to add my custom examples to the example finder and assign task-oriented browse paths and search keywords to them.  I can add new search keywords, but not new browse paths.  I understand if you can't reveal the information; if this is the case, you could consider it a feature request for the future.
Matt
Message 3 of 8
(3,684 Views)
Great, I have inquired with R&D about how to do this, if possible.  I post whatever I can as soon as I have word back (generally does not take more than a day)!
Best Regards,
JLS
Best,
JLS
Sixclear
Message 4 of 8
(3,672 Views)
Correction: "I post" should have been "I'll post" in the previous post 😉
Best,
JLS
Sixclear
Message 5 of 8
(3,669 Views)
Thanks.  I appreciate the support!  I look forward to hearing the answer.
-Matt
Message 6 of 8
(3,666 Views)
Has there been any progress made on this request?  I understand if the answer is "it can't be done."  If this is so, is it now possible with LV8?
-Matt
Message 7 of 8
(3,628 Views)
Sorry for the delay on that!  Yes, I checked with R&D and they said this would not be possible externally, as it would require a change in the example finder application itself.  I apologize that this is not an option for LabVIEW 8 either, as the structure of the example finder was fundamentally maitained.
Best Regards,
JLS
Best,
JLS
Sixclear
Message 8 of 8
(3,617 Views)
