How do i change 2 row of array into waveform with delta time and time
so the waveform graph will display two waveform,
waveform, not cluster =]
and how to extract 1d array from waveform?
(2,535 Views)
Hi AxE,
Here is an example VI, that do what You asked for.
Both requests.
Hope it Helps...
(2,536 Views)
I have read your vi. That is good. Thank you!
But do you think this vi is not efficienct?Although I am thinking of how to solve it.
(2,417 Views)
