Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How do i change 2 row of array into waveform with delta time and time
AxE
Member
09-17-2004
02:55 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
so the waveform graph will display two waveform,
waveform, not cluster =]
and how to extract 1d array from waveform?
0
Kudos
Message
1
of 3
(2,633 Views)
Reply
Re: How do i change 2 row of array into waveform with delta time and time
Bush-Man
Member
09-17-2004
03:20 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi AxE,
Here is an example VI, that do what You asked for.
Both requests.
Hope it Helps...
2D_to_Waveform.vi 75 KB
2
Kudos
Message
2
of 3
(2,634 Views)
Reply
hugoliang
Member
07-28-2006
09:41 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I have read your vi. That is good. Thank you!
But do you think this vi is not efficienct?Although I am thinking of how to solve it.
0
Kudos
Message
3
of 3
(2,515 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
