How do i connect a smoke alarm to labview
I have a smoke alarm EI100b, i need it to connect to labview. When the smoke alarm activate the labview will show an output message. By the way im also using the NI ELVIS 2+. Thx
(3,836 Views)
Does it have any kind of relay contact you can interface with?
(3,824 Views)
No. Is it possible to do so?
(3,822 Views)
You need to contact the manufacturer of the smoke detector to see if there is anyway to interface with it.
(3,820 Views)
Is any kind of relay able to help cause i have one. If it is possible how am i able to do it. Once again thanks for ur help
(3,812 Views)
duplicate post....again, try looking on the PCB for an IC switch(i.e., transistor, mosfet,voltage comparator, driver....)then take a voltage differential. You can do your part by naming the IC's(U#) or transistors(Q#) on the board. btw, show us your VI and what you have done so far?
(3,810 Views)
