How do i convert a picture back to a image array and extract the coulor table.
Been trying to do so for the past 2 weeks and the folks at NI India also are unable to support me. please help. I am on labview 6.1
Ankur
(3,003 Views)
I suppose that you are talking about a LV picture.
My opinion is that LV 6 was an absolute pity for picture management. LV 7 is only a pity.
Your problem could be solved in a breath using a few of the IMAQ vision tools. Unfortunately, NI has decided to keep separated its image management tools from its graphic development environment. I think that this situation should be discussed...
With LV 6, there is probably a solution that use the Flatten to String function, convert the string to a 1D-array of bytes, remove the 32 bytes or so the Flatten function has added before the actual picture bytes, then reshape the array according to the initial picture size. I have done that in the past for a 8byte picture. Not sure if it is as simple for a colored picture. Not sure either if I'll have some time to spare on the problem today.
Hope you will find here some more constructive help !
CC
Chilly Charly    (aka CC)
(2,997 Views)
Dear chilly,
Tried unflattened to string. was able to extract the image array but not the color table nor the image bit depth. please advise. i am on LV 6.1
Ankur
(2,994 Views)
Chilly
Also the extracted array was of 8-bit size and not any other bit length. no 1 bit or 24bit or.....
Ankur
(2,998 Views)
Answered here
CC
(2,969 Views)
