How do i import images stored in a folder sequentially and add a timer to change in sequence?
There are several ways to do this, but I don't think it will do what you want.  You can right click the image and say Fit to Pane which will then resize the control to take the whole window.  However this only resizes the control not the image.  For that you'll likely need a property node with the Zoom Factor set.
http://digital.ni.com/public.nsf/allkb/55EEBE3A1ECC38F58625765600796F1C
If you do want an other window you can make it a subVI showing the image so no other controls are seen.
Message 11 of 14
(591 Views)
You are right sir. Can you please suggest me where can I learn Labview from the beginning?
Message 12 of 14
(590 Views)
I guess that will work. I will do the rest Sir. Thank you and I will start learning soon. Please provide me the information about wher can I learn from the beginning.
Message 14 of 14
(584 Views)
