How do i import images stored in a folder sequentially and add a timer to change in sequence?
I am actually very new to Labview and I do not have much idea about it. Can anyone provide me a VI which can import images stored in a folder sequentially.
Example: the images stored in the folder have names like 1.bmp,2.bmp and so on...
I want to import 1.bmp first and after 8 seconds 2.bmp and so on..
Please help me with  this.
Message 1 of 14
(4,552 Views)
Hi!
If the images are labeled in a way that they will be sorted correctly by name, the task is trivial.
Have a look at the snippet below.
Best regards
Dan
Message 2 of 14
(4,522 Views)
Thank you so much for replying. I basically cannot read the diagram as I mentioned that I am very new to all this. Could you please provide me the VI if possible. I highly appreciate your help,
Message 3 of 14
(4,518 Views)
What was posted was a Snippet.  It is a VI just saved as a picture.  Drag the image from your browser to a folder on your computer.  Then Open LabVIEW 2013 (the version the snippet was saved in) and drag the file from your computer to your block diagram, it will then have the code in it that is shown in the picture.
Message 4 of 14
(4,513 Views)
Thank you so much Sir. But the version which I am using is Labview 2012. It is unable to accept that.
Message 5 of 14
(4,510 Views)
Awesome SIr. This is working. Thank you so much Sir. I highly appreciate your support.
Message 7 of 14
(4,498 Views)
Accepted by topic author santosh122333
Hello again!
Ok, so i saved the vi in LabVIEW2012 for you.
But really, you should take the introduction course to LabVIEW or something. You wont get far if you cant even reproduce that pretty simple vi.
//Dan
Message 8 of 14
(4,493 Views)
Your welcome, the best way to say thank you is with Kudos, and marking the solution (in this case Dan's post)
Message 9 of 14
(4,492 Views)
Also, is it possible to open the image in a separate window as the image has to be projected.
Message 10 of 14
(4,489 Views)
