01-04-2013 12:18 AM
How do i create a vertical cursor that is movable? I really need some help with that! I need the cursor to be able to move and read the readings from my graph. Can anyone teach me? thanx! Here is my vi!
Solved! Go to Solution.
01-04-2013 12:28 AM
Right click on graph > visible items > Cursor legend.
Then you can create cursors.
Bijay
01-04-2013 12:34 AM
I have tried but when i run the program, there isnt any cursor moving. Why is that so? Here is my vi.
01-04-2013 12:46 AM
As Vijay said and you already implemented. In your graph cursor is there but if you see carefully your cursor x/y value is out of x/y scale range.
Do one thing just right click on your cursor under cursor pallet and select bring to center or go to cursor option.
01-04-2013 12:52 AM
Thanx for the solution! It works! 🙂
01-04-2013 01:35 AM
Mark the post as solution if issue is solved. ![]()
Bijay
