How do i reset a feedback node insade a case structure?
Hello, i have this problem: basically each time the case structure changes from false to true, i want the feedback node to start from 500 instead that from 0. With the feedback node in photo once the value has reached 0 the case structure changes to false, what i want to do is that when it goes back to true i want it to start from 500, how can i do that?
Thank you
(2,329 Views)
The shift register seems more suitable in your case.
(2,321 Views)
Tried but its not what im searching for, i need a function that, starting from 0, increments until 500 and then decrements back to 0, continuously
(2,314 Views)
Accepted by topic author domcorrado
With a feedback node:
(2,310 Views)
You can avoid the case structure:
(2,302 Views)
Thank you, we love you
(2,298 Views)
