This widget could not be displayed.
How do one generates multiple continuous digital signals in multiple pins on an DAQ 6259 machine and at the same time one can change the frequency and duty cycle of each digital signal at will?
(3,498 Views)
Hi there, take a look at this example. It should get you started.
Alejandro C. | National Instruments
(3,472 Views)
That helped out a lot, but do you know of such a way for every signal to not only have its own duty cycle, but also its own frequency. From the program I received from you I was only able to make changes to each individual signal's duty cycle but they all shared the same frequency. So I want each signal to have its own duty cycle and its own frequency in which I can make changes to. Thanks
(3,452 Views)
I did a little search and I found the following example. Normally, it's possible to find code that is really close or does exactly what you need if you keep looking. I hope this helps
(3,426 Views)
Thanks that is a great example I'm just having a few problems with the program. This error pops up everytime:
(3,414 Views)
