How do you add a device in MAX after getting Error 200220
I am receiving the following error when I launch my datalogging software
When I open MAX, I noticed that the NI device I am using (USB-TC01) is not listed.
Would anyone out there be able to let me know how do I add the the TC01 device? I know I need to go to the 'Create New' icon in Devices and Interfaces, but not sure how to proceed after that. I get the following screen but unsure what to select.
I'm using the 9.0.2 version of the NI-DAQmx driver on WinXP OS.
Thanks for your time,
Kevin
(2,524 Views)
Accepted by Kevski
You might need to upgrade your DAQmx driver.
Look at this page.  http://sine.ni.com/psp/app/doc/p/id/psp-916/lang/en
All the DAQmx versions listed are newer than the 9.0.2 you are using.
Also, take a look at this message thread.  https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/NI-USB-TC01-not-found/m-p/1454196?requireLog... which seems to confirm this.
(2,516 Views)
Thanks, I installed version 9.2.3 of DAQmx and my datalogging software works perfectly now.
Kevski
(2,503 Views)
