How do you avoid local variables?
@AlbertoEnciso wrote:
I did 3 clusters:......
3 clusters means 3 shift registers.  You can do it all with one shift register.  Did you know that you can bundle your 3 clusters into one main cluster.  Clusters within a cluster.  Then you would only need one shift register.  See example below:
An alternative to putting your clusters into one main cluster is to wire your clusters into a bundle function.  The output is the same as the main cluster above.
- tbob
Inventor of the WORM Global
Message 21 of 21
(1,003 Views)
