How do you convert a 32bit row array to a decimal number?
I have a 32bit row array that I need to convert to a decimal number.
Could someone please help?
(3,676 Views)
I am not sure what you are asking.
You have an array with 32bit Integers and you want a decimal number? Like an average or something?
OR you have an array of 1's and 0's with a length of 32, that you want converted into the integer value??
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(3,670 Views)
Number 2. I have an array of 1's and 0's with a length of 32, that I want to convert into a interger value.
(3,666 Views)
Use a For loop to index into the array, then use the Not Equal To Zero comparison to convert it to true/false. Then Index out of the For and use the Bool Array to Int from the boolean pallete.
Here is an example in 8.2
(3,663 Views)
Thank you very  much!
It works great!
(3,646 Views)
n/m
Message Edited by nickveys on 11-15-2007 04:01 PM
(3,641 Views)
No need for the For loop. Just wire the array directly to the Not Equal to Zero function.
(3,634 Views)
